TwinTurbo.NET: Nissan 300ZX forum - What is a "Canyon Carver" reroute? (n/m)
Woody75 (Denver)
on November 08, 2014 at 4:11 PM
The "Canyon Carver" reroute did not reduce pcv gunk build-up
posted by flashstar
on November 06, 2014 at 05:26 PM
Catch Can Setup Help
flashstar
15:42:28 11/06/14
Reroute = simple as possible. (n/m)
Woody75 (Denver)
16:31:33 11/06/14
flashstar
17:26:25 11/06/14
I did the reroute and in-line installed a catch can..
ShakaShaun(Denver)
19:34:03 11/07/14
Where in-line did you place the catch can? How did you take
flashstar
23:54:18 11/07/14
What is a "Canyon Carver" reroute? (n/m) -
Woody75 (Denver)
16:11:41 11/08/14
^^ 2nd ^^ (n/m)
ttz'in (NorCal)
11:37:58 11/09/14
"Canyon Carver"'s Re-Route on 3ZC. Reverse PCV Air Flow
flashstar
13:39:46 11/09/14
Use the reroute I have in the VTF section. Works fine. (n/m)
Woody75 (Denver)
09:30:58 11/10/14
Agree, well written & illustrated Tim. (n/m)
ttz'in (NorCal)
11:17:23 11/10/14
^What?
-Grimm-
12:48:38 11/10/14
Sounds correct, but Woody75's re-route eliminates
ttz'in (NorCal)
15:25:18 11/10/14
I eliminated it on mine also
-Grimm-
16:19:14 11/10/14
same. as per SZ advice (n/m)
LivinTheDream
19:21:19 11/10/14
Does Woody's re-route reduce the oil mist problem?
flashstar
19:06:57 11/10/14
If there is any the reroute wont remove it. the re route
LivinTheDream
19:25:41 11/10/14
Will sending the crankcase gases through the cat-pipe damage
flashstar
19:54:37 11/10/14
Your exhaust can pull a vacuum
-Grimm-
10:30:10 11/11/14
Member zinnz32 has done this. dont know about cats (n/m)
LivinTheDream
22:48:52 11/11/14
This is INCORRECT. NO FRESH AIR GETS BLOWN ANYWHERE (n/m)
LivinTheDream
19:19:44 11/10/14
SZ recommends....
LivinTheDream
06:43:21 11/08/14
Unfortunately, I have a NA engine. Here's my plan though
flashstar
13:48:46 11/08/14
They will also close when boosting
-Grimm-
18:40:45 11/08/14
I guess that's one of the few benefits of a NA ;) (n/m)
flashstar
21:42:30 11/08/14
If only I read... (n/m)
-Grimm-
12:49:41 11/10/14
Then would it be possible to connect intake VC hoses
ttz'in (NorCal)
15:31:24 11/10/14
not on a turbo. when the plenum is under boost the crank
LivinTheDream
19:15:03 11/10/14
Sounds good to me. Always wondered if a catch can is
LivinTheDream
23:36:02 11/09/14
Not if you get busted venting to the atmosphere. (n/m)
ttz'in (NorCal)
11:20:24 11/10/14
inline of course venting to the turbo inlets. (n/m)
LivinTheDream
19:27:25 11/10/14
Re: SZ recommends....
Z ONLY1
15:33:37 11/10/14
did u add an inline catch can and if so collect anything? (n/m)
LivinTheDream
19:28:50 11/10/14
Re: did u add an inline catch can and if so collect anything?
Z ONLY1
06:46:24 11/11/14
